Okay I can capture video fine, but I can't capture any audio. When I go back to play the clip no sound. I'm not sure what's wrong. I have the audio from my composite (rca) jacks running into my soundcard line in. I turned up the sound under my sound properties for recording. I made sure that my sound card was shown under that same option. I use Cd quality for my sound and the attributes are 44,100 hz, 16 bit stereo, 172 kbits. I'm capturing from a camcorder using a Cybermail capture card. I'm not sure what the problem is. Do I have to save the audio as a seperate file? I didn't think I had to since I'm locking the video stream to audio. Thanks for any help!
G,
Make certain that line-in under the Volume Control Recording properties is enabled. Had that happen to me once.
Regards,
The Daywalker -
Thx Daywalker. Your suggestion actually led me to the source of the problem. My line in volume was turned way down for some reason. I upped the volume and presto!
VDub Problem
By heygurl in forum SubtitleReplies: 8Last Post: 9th Dec 2010, 19:38 -
Best Vdub deinterlacer?
By brassplyer in forum RestorationReplies: 14Last Post: 25th Apr 2010, 22:50 -
VDub Help..!!
By scratchlikeme in forum Newbie / General discussionsReplies: 3Last Post: 17th Nov 2009, 07:40 -
vdub -> wmv?
By zapster in forum EditingReplies: 10Last Post: 17th May 2008, 21:16 -
vdub and audio
By jimbb in forum AudioReplies: 1Last Post: 9th Apr 2008, 11:17
