  1. i just cut out a few clips from a mpeg file and then i combined them together. but for some reason after i combine the files the time length in media player says the video is 2mins and 12secs long, but when i move the bar all the way to the end the video keeps going to 3mins and 30secs. how do i make media player see the whole video?
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    forget media player --- its hopeless on reporting correct time
    maybe media player classic is better (it is at everything else vs. media player)
  3. it worked fine with the other mpeg files, its just this one that messes up
  4. Член BJ_M's Avatar
    Jul 2002
    Canada
    use a better mpeg editor .
    dont use vbr mpeg (in this case)
    one or both of the above
  5. i used a few different ones, they all give a different length in time when i open it with media player and none of them have the whole time. is there a specific one you were thinking about?
  6. I'm a MEGA Super Moderator Baldrick's Avatar
    What did you use to join the mpgs? Some editors does NOT fix the mpg headers so the total time gets messed up.
  7. i used iFilmEdit and tmpgenc. i just copied the file to another computer and the media player on that computer sees the whole length. so i guess there is nothing wrong with the file, its my media player
