i was wondering if anyone has used it, if it worked good and which one they used.
i need the xvid codec to play some movies and was just wanting some feedback before i download one.
thanks for your time.
nightscape
nightscape
Nightscape,
I have used the Xvid codec available from this site for months with no problems at all.
However, should you wish to run it through TMPGEnc, you'll need to set a few options up. Here's a guide on this site that will help you to do this:
https://www.videohelp.com/forum/viewtopic.php?t=119019&highlight=xvid+reader+priorities
Enjoy.
CobraDMX -
Can it be installed alongside older DivX codecs like 4.11? Also, I heard that the later V5.x codecs might possibly contain spyware/adware, any truth to the rumours?
If you choose not to purchase DivxPro 5x, then it indeed has adware in it, but it comes with full functionality. If you purchase it though, it comes adware free.
To answer your other question, yes, you can install it next to the others. Make sure you install them in order (i.e V3, V4, and then V5) for the DivX codecs. XviD can be installed along side all of these without issue. It will produce equivelent, or better quality than the DivX codec, and it's freeware.
Impossible to see the future is. The Dark Side clouds everything...
Nonsense description for Lagarith (tools section)
By lordsmurf in forum FeedbackReplies: 4Last Post: 30th Dec 2011, 13:28 -
A couple more programs not listed in the TOOLS section
By Seeker47 in forum Latest Video NewsReplies: 1Last Post: 25th Nov 2011, 12:32 -
How do we get our video editor listed in the Tools section?
By MacheteSoft in forum FeedbackReplies: 4Last Post: 18th May 2009, 23:06 -
Xvid won't play on device. Plays on computer. GSpot has blank Video section
By cryptyk in forum Newbie / General discussionsReplies: 11Last Post: 13th Sep 2008, 23:53 -
Video Codec Tools
By Bobbyn in forum MacReplies: 1Last Post: 7th Aug 2007, 09:44
