Hi, I've been converting divx, xvid etc to svcd for a while now, so I thought i'd upgrade to dvd, as far as i can make out from the guides the process isn't that different that it is with SVCD.
Am i right in saying that if want to make a dvd with ac3 sound, i can extract the ac3 track froma divx with virtual dub (using direct stream i presume) the fix it with ac3fix, convert the video only in TPMGenc and then use the two files to author a dvd?
Also is it possible to convert a stereo track off of an avi and convert the audio into ac3 with besweet or hav i lost the plot here.
Cheers
Phil
No that's pretty much it. Remember to encode a DVD standard resolution thou (720x480, 352x480 or 352x240).
Once you have the elementary streams (m2v and ac3 files) you'll need to author the DVD (generate the VOB and IFO files). There are a lot of programs that can do this (look to the left under author).
Freeware wise, if all you want is a movie (no menus, extras, special tracks, etc) IFOEdit works fine.
DVD Authoring for MKV files and dts, ac3 support
By anfield7 in forum Newbie / General discussionsReplies: 2Last Post: 10th Oct 2011, 16:32 -
Converting AAC to AC3 (for DVD authoring), losing audio
By senorroboto2k5 in forum AudioReplies: 3Last Post: 16th Feb 2010, 18:03 -
DVD authoring ac3 out of sync after authoring but not before
By Genaugmen in forum Authoring (DVD)Replies: 1Last Post: 29th Jan 2010, 19:16 -
Re-Authoring A DVD With LPCM>AC3 Audio & Fewer VOBs
By DeathStalker77 in forum Authoring (DVD)Replies: 5Last Post: 25th Dec 2009, 11:25 -
Authoring a DVD with AC3 640 bitrate - can it be done?
By Slimbo69 in forum Authoring (DVD)Replies: 11Last Post: 9th May 2008, 09:11
