Hi,
Has anyone done any comparable tests between the two above technologies.
Rockwell/Brooktree/Conexant/Fusion 878 based chip have been the chip of choice for many years in anologue capture cards.
The Conexant 23880/1 chip are present in new anologue capture cards from ASUS, Pixelview and MSI and is the new successor to the 878 chipset
These boast some new features like "Adaptive multi-line 2-D comb filter" compared to "Luma Notch and Chroma Comb" from the 878 chipset should give a better filtered picture with a better chroma content, 10bit capture compared to 8bit capture, it should give a higher dynamic range.![]()
The new chip should produce clearer capture from say a composite video signal. Has any one done any comparisons using say Huffyuv saved to some test avi's![]()
Results 1 to 1 of 1
Converting for NPower Fusion - DeviceConformanceTemplate setting?
By DVantrease in forum Video ConversionReplies: 3Last Post: 31st Dec 2009, 16:38 -
bt conexant 878a darker band on bottom has appeared
By video_magic in forum Capturing and VCRReplies: 0Last Post: 3rd May 2009, 23:41 -
Anyone know how to convert videos for NPower Fusion player?
By DVantrease in forum Video ConversionReplies: 0Last Post: 7th Nov 2008, 00:49 -
Opinions on Fusion HDTV Tuner Cards
By peggypwr1 in forum Newbie / General discussionsReplies: 5Last Post: 23rd Aug 2008, 13:02 -
Which is better? Conexant CX23881 or Phillips TDA8290, TDA8275 Chip
By ffxdean in forum Capturing and VCRReplies: 3Last Post: 15th Jul 2007, 21:55
