I have the Panasonic Encoder 2.51 (I know TMPGEnc is better, but my CPU is only 400). I went to the tutorial on converting to VCD using Panasonic Encoder 2.51 (a link in case you are not fimilar with this encoder, http://www.vcdhelp.com/panasonic.htm) and step 3 I find confusing. Here is the original quote:
Special Processing
1. Here you can add borders if you want to remove something or to squeeze the movie. Or just remove noise headears ( if you have a DivX-movie you often have to add black borders to ge correct ratio, to calculate the correct ratio: example with movie in 640 x 304
for PAL-movies(25fps)
640 / 1.222 = 524 - 304 = 220 / 2 = 110 pixel
both Top and Bottom
for NTSC-movies(29,97fps)
you divide with 1.466 instead of 1.222.
After doing the math for my movie (and adding a border I checked my encode. I looks fine. I also checked my encode without the adding borders and it also worked. Do I have to do this or not.
This particular movie is a DVD Rip (23.97fps 640x360)
Is there a rule of thumb (e.g. I MUST do this for every movie no matter what format)?
Thanks in advance.
Sorry if it is confusing
Does anyone have an thoughts?
Any ideas would be much appreciated.
Thanks in advance -
Hi,
I know this can be confusing with Panasonic and its probably the reason why i stopped using it and went to TMPGenc...... by the way i would still recommend using TMPGenc as i am running a PIII 500 and it is working very well.
Your example would be approx 38.3 for the TOP and BOTTOM borders and as a general rule of thumb yes you should calculate this all the time...
regards
Resizing With ffdshow?
By Prince Valiant in forum Software PlayingReplies: 1Last Post: 18th Mar 2012, 01:48 -
resizing...
By backslash in forum LinuxReplies: 1Last Post: 4th Jul 2010, 17:14 -
resizing
By marcopolo1 in forum Video ConversionReplies: 7Last Post: 11th Oct 2009, 18:06 -
Resizing question
By tb582 in forum Video ConversionReplies: 1Last Post: 16th Feb 2009, 14:56 -
resizing help
By shaktiIIIgta in forum Newbie / General discussionsReplies: 14Last Post: 15th Nov 2008, 21:52
