does anyone know what i can use to cut avi files other than virtualdub and nandub?
Results 1 to 12 of 12
Did you look to the left under "Edit"? There are a million and one programs that can do this (note avi and DivX are not the same thing
I personally like VDub, Vegas Video, and Ulead Media Studio. -
one is virtualdub and teh other is avichop. i already tried avichop and it doesnt work for me
the reason i don't want to use virtualdub is because it always cuts out more than i want from a video. i tried to save that video and then edit it to shorten the length but it doesn't work the second time for some reason. can someone tell me why?
Vdub will probably jump to the nearest key frame and save to there..
You can also use TMPGEnc file > output to file > AVI
Just use the source range. -
Originally Posted by King-John"Art is making something out of nothing and selling it." - Frank Zappa
using source range, i am experiencing sound problem with a certain avi that i d/l.
i noticed that as i edit, the audio display showed no sound level, just a flat line...as i encode a sample ...sure enough..no sound.
the avi plays with sound using mplayer or divx.
i check with GSpot to see if there was something wrong with the avi...nothing?
i even tried to de-multiplex the file...only to get a big sound file of silence?
i am using TMPGEnc plus 2.5 and was wondering if there is any problems that is inherent to this version? or has anyone experienced this type of situation and how was it solved?
i'm truly puzzled. -
Originally Posted by jollibee"Art is making something out of nothing and selling it." - Frank Zappa
I can edit 100% in VirtualDub. There's none of that key problem.
I edit the cut using frame by frame move, it's perfect.
It just need some extras, like fade.
Help with editing an avi
By VanZan in forum EditingReplies: 6Last Post: 20th Nov 2011, 07:06 -
avi editing
By einarinari in forum Video ConversionReplies: 4Last Post: 18th Feb 2009, 15:06 -
Editing an .avi in FCP
By macmithos in forum MacReplies: 2Last Post: 20th Jul 2008, 15:27 -
Editing an AVI file so I am just left with the VIDEO Avi (No Audio)
By incrediblej in forum EditingReplies: 6Last Post: 26th Mar 2008, 19:16 -
Editing: MPEG2 vs DV AVI
By daamon in forum EditingReplies: 6Last Post: 5th Sep 2007, 11:35
