Yes, I know this is three years on.
The original post says
What is this "batch process" in TMPGE doing?Then we want to (LOAD) a default TMPGEnc Template. Choose (VideoCD NTSC.mcf), you can use PAL if you are not in the states. NEXT you will want to load the VCD source file...........
Then click on (FILE) (ADD CURRENT PROJECT TO BATCH LIST) (MPEG FILE), you will do this over and over until you have all of the VCD'S loaded into the batch process......
Does it just read an MPEG1 and write it back in the same format? Presumably this tidies up timing errors from edits? Is the video resampled -- i.e. is there any loss of quality? 45 minutes per file sounds like it's resampling.
I've found I can fix sync problems in VCD-> DVD by first running the file through MPEGVCR's GOP fixer. Also VCDGear has a "fix mpeg error" function that seems to improve files; both these only take a minute or so per file so can't be resampling.
Results 61 to 61 of 61
Multiple AVI is WINAVI being put on DVD in the wrong order
By richco in forum Authoring (DVD)Replies: 7Last Post: 23rd Nov 2009, 07:50 -
multiple questions here so i'm not sure where to put this
By pmmassacre in forum MacReplies: 10Last Post: 12th Jun 2009, 08:49 -
Taking portions of multiple dvds and put them onto another
By ulremember in forum Authoring (DVD)Replies: 10Last Post: 4th Mar 2009, 19:07 -
Time to finally put DVD Decryptor to bed...at least for Liteon recorders...
By oldfart13 in forum DVD & Blu-ray RecordersReplies: 5Last Post: 4th Oct 2007, 13:55 -
Can I put multiple video files onto one DVD?
By flameout in forum Authoring (DVD)Replies: 4Last Post: 17th Jul 2007, 16:12
