Hiya, Here is my problem.
When i am ripping one of my DVD's using Smart Ripper, i am putting the VOB's thru DVD2AVI, When the Encoding has finished the Audio track comes out like the Smurfs are speaking.....
If any one can help me and suggest any types of freeware that i can use to put the speed of the Audio back to normal all/any help will b gratefull
Thank's J.
Well you can configure DVD2AVI to output the AC-3 track or decode it to a WAV file.
I just let it extract the AC-3 then I use either BeSweet or Headac3he to then convert the AC-3 file to a WAV file. For me Headac3he doesn't always work with 5.1 AC-3 sources ... I don't know why ... so I use mostly BeSweet and the BeSweet GUI
- John "FulciLives" Coleman
P.S.
When I use Headac3he with 5.1 AC-3 source files I sometimes get some sort of "overflow" error."The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
How to Convert 2 channel stereo wave into DD5.1 AC3 448 / AC 640
By Bonie81 in forum User guidesReplies: 36Last Post: 2nd Feb 2018, 13:42 -
mpg -> AC3 -> mono wave files.
By jocorok in forum Video ConversionReplies: 3Last Post: 24th Jul 2009, 03:15 -
audio levels keep changing, 5.1 ac3-to-wave
By spiritgumm in forum AudioReplies: 0Last Post: 22nd Mar 2008, 10:56 -
Belight settings for correct wave/ac3 volume conversion?
By spiritgumm in forum AudioReplies: 0Last Post: 29th Feb 2008, 13:19 -
WMV to DVD conersion
By uniks in forum Newbie / General discussionsReplies: 6Last Post: 31st Aug 2007, 08:25
