So, I just burned another test movie with the Pioneer fix.
And... big thumbs down.
The video is... better. It's on the screen at least, and it's smooth but JITTERY. Looks like the frames aren't interlacing correctly anymore or something. What should be a still picture sort of looks like it's wavering up and down. Yikes!
And ... my DV-525 (Pioneer) REFUSES to play the audio produced by SVCD2DVDMPG+ & BeSweet. AC3 just clicks and pops. MP2, on the other hand, plays... but breaks up. I get 2 second snippets of sound.
I'm wondering what my issue is here?
And the source movie in question looks and sounds fine as a SVCD.
Additionally, after applying the Pioneer fix... the DVD I created looks vertically squished in both PowerDVD and my PS2. I know that's not a great selection of reference players, but it's all I've got.
So the problems are threefold:
1. Jittery video.
2. AC3 = AWFUL, MP2 = Pretty awful.
3. Pioneer fixed video = BAD in non-pioneer units.
Help?
- Gurm
The ac3 problem is a common problem, because the besweet ac3enc does not create fully compatible stereo dolby digital(ac3) audio files. If you want better ac3 compatibility you have to convert with another ac3encoder, like sonic foundry soft encode but it is no longer sold. I don't know any other standalone ac3 encoder, but some authoring tool have built-in ac3 encoders like dvdit pe, neodvd and ulead workshop ac3.
feeky1973Guest
baldrick
i have this same problem with be sweet, so i thought i would give soft encode a try.
but im not having much joy, i extract the audio from the avi using nandub so its saved as a wav file but when i try and open it in soft encode it doesnt like it saying it might be in compressed format
help
feekster
p.s. what is dvdit pe is it any good?
Whats the best way to fix Sync issues in MKV?
By KushSmoka420 in forum AudioReplies: 2Last Post: 21st Feb 2012, 09:53 -
A Pioneer DVD fix it problem
By kenmt in forum DVD & Blu-ray RecordersReplies: 6Last Post: 23rd Jul 2010, 08:03 -
Pioneer DVR video outputs not working - possible to fix? other options?
By JimmyMcV in forum DVD & Blu-ray RecordersReplies: 2Last Post: 10th May 2010, 23:59 -
How do I fix DVD sound and volume issues?
By soneman in forum AudioReplies: 9Last Post: 8th Sep 2009, 17:50 -
Trial Version of Video Studio 11 hot fix issues, how do I install??
By JediPM in forum Newbie / General discussionsReplies: 8Last Post: 6th Feb 2008, 13:00
