  1. i've downloade two mpeg2 clips 480x480 29.97 fps
    file 1 -759 mb 51:17 min
    file 2 -779 mb 50:33 min
    i want to burn each file on a 700mb cd so i've tryed to convert it to avi(divx 4) with the moded version virtualdub mpeg2-ac3 but after the conversion there wasn't any audio sync and quality was greatly reduced and the strangest thing is that no matter how high i raise the bitrate of the movie the size stays about 500mb. Maybe someone can suggest a better way to do the job or just leave the file in mpeg form and only to reduce it's size. thanks in advabce and sorry for my bad english
    ---===SATURN===---
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Author as SVCD, and you're fine! Using the (S)VCD format, you can squeeze almost 800 MB on a 80 min CD. Judging by the resolution, frame rate and size, they are in fact NTSC SVCD compliant mpegs.
    /Mats
  3. i've tryed to use tmpgenc but it would not open the file saying it's in unsupported format and yes i've installed a mpeg2 codec so maybe someone could suggest how to turn the files to avi or just reduce their size to 700mb leaving them in the mpeg2 format
    ---===SATURN===---
  4. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Again: Just author and burn as SVCD and you will have your wish: one file per CD. Use VCDeasy to author and burn. Most likely no need to run'em thru TMPGEnc.
    /Mats
  5. Member Timoleon's Avatar
    Oct 2002
    Magellanic Clouds
    Use Vidomi.
