Hi,
This is a very newbie question for you guys!! So please answer me!!
I have quickly and easily converted a DivX film to SVCD with Pinnacle TRex. Now I have a a 1.4G mpeg2 file that I want to cut so I can burn my SVCDs. In TMPGEnc, MPEG Tools I have to choose Start time and End Time of the piece of file to cut.
Now, I choose start 00:00 and the question is: how do I know the End time so I can get the file size that best fits a 650M or 700M CDRW?
How do I know how many CDRWs will I need? I suppose that (from one of the newbie guides I can fit 735M / 795M on 650M/700M CDRWS, right?) it will be 2 CDRWs only, right?
Thanks!!
Dashur
mine 2 cents..
it depends on how many cds you want to use and what size they are:
1.4 GB can be put on 2 x 700 MB cds breaking point of the mpeg somewhere in the middle. Take the time of the movie and devide by 2, go there and move forward of backward till the begin/end of a scene and cut.
It could be cause of the scene 1 of the mpgs will not fit then you cut it right in the middle of a scene or take another cd. devide the time by 3 and do the proces for 3 cds..
yf
Long Encoding Times - MPEG2 --> XviD?
By onesikgypo in forum Newbie / General discussionsReplies: 16Last Post: 13th Oct 2009, 08:06 -
DVD to H.264 - Different Running Times, Chapter Times Wrong
By nrogers64 in forum Newbie / General discussionsReplies: 0Last Post: 17th Mar 2009, 19:28 -
How to automatically split a .dv file at certain times
By conrad787 in forum MacReplies: 3Last Post: 21st Oct 2007, 09:41 -
What AVI File Size Should I Choose
By Dubinvero in forum EditingReplies: 2Last Post: 22nd Sep 2007, 23:05 -
SVCD / MPEG2 - bad packet stops file.
By Steve Walsh in forum Authoring (VCD/SVCD)Replies: 5Last Post: 9th Jul 2007, 13:03
