i do not mean to crosspost .. and I am actually not as the above rule states to not post in several forums ... I am staying in the same forum .. even the same thread![]()
but this thing is bugging the heck out of me ... and i know it has to work somehow ...
i'd be particulary interested inin a guide for DivX -> whatever (VCD / DVD) as i have trouble hooking up my TiBook to the TV
a first test in 0.0.6 created something good looking but audio totally out of sync ...
in 0.0.7 i run into a nice error message: after a nice .mp2 file is created (now i can listen to the whole movie .. alas not on the iPod)
**ERROR: [mplex] Unable to open file /Users/meman/Desktop/tv showsXViD-DVL/pb.m2v for reading.
as it has not created a m2v file .. but an mp2
i even tried renaming the mp2 into m2v and ran the encode again .. did not work either ..
any ideas?? thanks
(ok .. a bit more detail as to what I am doing: running 10.2.6 on a g4 1 GB tibook .. i load the avi into ffm and then just select the quick presets .. i tried that for VCD, SVCD and DVD .. and nothing worked out so far .. i must be doing something really wrong .. yes .. i used the installer and have the 3 components loaded ..
Thansk in advance !!!
Results 1 to 13 of 13
As a related point what kind of problems are you having hooking your Titanium to the TV?
I assume that the 1Ghz still have S-Video out?
With the later version of OS X and Powerbooks they are very picky about hooking up to external things. And it's usually the opposite of what Apple recommends or recommended.
I find that if you hook up monitors "hot" (laptop screen open, power on) it usually works better. Hooking up while asleep or powered off sometimes causes problems.
first of all ... MAJOR is the man !!! yeas !!!
worked exactly as he said .. needed to change the folder name so that there is no blank in it .. .and checked that the source file had 25 fps (PAL) .. so i made A PAL VCD this time ... not NTSC as i tried before .. gladly my stand alone player and TV can handle all that ..
as to my TV hookup problem ... i figure it may be related to the fact that I try to route that (as all my AV equipment) through my sony 940 DB amp ... i have only given it a quick try ... want to see what happens when I hook it to the TV directly ...
thanks to both of you !
P
Oh .. and if further tests go just as well as the first (running into very siomilar trouble now with the next file I am trying ... looking for an m1v while it had so far only created an mp2 ... ) , rest assured Major that my 15$ will be on the way !
thanks again
(now .. how / what to do with vobsubs files that came with one divx file ? oh .. i am digressing )
trc3Guest
I keep getting the same error...
**ERROR: [mplex] Unable to open file /Volumes/Footy/todd/footy.m1v for reading.
It never makes a .m1v file! I was getting the error before but took out all the spaces and numbers and I'm still getting the error. Any ideas?
If you're talking about subtitles coming in two files (one .idx and one .sub) you can display them by selecting the .idx file in the Load sub.. field, then open the video in the Open.. field and click "Play" button (this button is located to the right of the Open.. field).Originally Posted by caipirina
trc3Guest
Umm.. I don't really speak terminal, I'm trying to learn. So looking at the output really doesn't tell me much. I have no idea why its not making a .mv1 file... I'm trying to convert divx to vcd using the preset vcd option. The only thing I was changing was the resolution. I didn't want 720x480 I had it at 700x303(dont ask I just wanted it that size) could this have something to do with it? Thanks in advance if anyone can help.
FFmpegX MP4 to DivX/Xvid No Audio
By TDC_01 in forum ffmpegX general discussionReplies: 4Last Post: 21st Nov 2009, 20:49 -
Mkv to divx with ac3, ffMpegX will not encode anymore.
By biggyk in forum ffmpegX general discussionReplies: 15Last Post: 31st Jan 2009, 16:48 -
VIDEO_TS to DivX w/ ffmpegx
By motherwell in forum MacReplies: 2Last Post: 7th Apr 2008, 16:10 -
DivX to DVD with FFMpegX - result jerky
By akulier in forum ffmpegX general discussionReplies: 5Last Post: 19th Feb 2008, 17:40 -
ffmpegX 0.0.9 Video_TS to DivX
By stcowboy in forum ffmpegX general discussionReplies: 10Last Post: 29th Dec 2007, 03:11
