SYS Spec:
AMD XP 1800
Asus a7v333 w onboard sound
512 mb RAM DDR PC- 27000
G4 TI 4600 DDR 128mb
Pioneer A-104 DVD-R/W
Western Digital 80 gig 7200 rpm
Windows XP SP1
DVD-r Media = DVDpro Grade A
Home DVD player is KLH HA7000
Hi,
I have ripped my dvd with smartripper under defult settings. I rip the video file ([0xE0] Video NTSC/16:9/720x480), the audio, the subtitles and the others. After I rip them, I place all the files in a folder called VIDEO_TS and create another one called AUDIO_TS and the burn it on a dvdrw.
After I burn it, my home dvd player is stuck on "LOADING" while it plays fine on the dvd drive on my computer.
I have used the same media with movies which I didnt encode and they worked fine. And then some other movies I didnt encode had same problems. I used Tempgenc to encode them.
I’m sure I have to edit the IFO file but have no idea what I should do.
I have aslo tried buring in UDF1.02
Any suggestions would be greatly appreciated.
Thank you.
dont bump you post ..
you have to author your raw m2v and ac3 streams .. before burning .. guides to the left .. (doitfdast4u is a great program btw)
Windows 7 Stuck in "read only" mode for USB THumbs and SD Cards etc..
By nerys in forum ComputerReplies: 26Last Post: 1st Mar 2012, 02:03 -
SOLVED!! - AutoMKV stuck on "parsing profiles"... (not respondin
By TooLFooL in forum DVD RippingReplies: 7Last Post: 3rd May 2008, 08:35 -
Panasonic DMR-ES10 "LOADING"-type problem
By lordsmurf in forum DVD & Blu-ray RecordersReplies: 3Last Post: 14th Jan 2008, 23:52 -
I'm totally stuck "unrecognised message" and other errors
By marinebc11 in forum MacReplies: 22Last Post: 26th Aug 2007, 17:32 -
Avi2DVD message when loading AVI...."DV DVI Detected"
By geek2330 in forum Newbie / General discussionsReplies: 3Last Post: 22nd Jun 2007, 07:05
