I'm looking at some laptops right now and comparing prices. Some of the models that I'm interested in are shipping with XP Home, which I don't want to run. If I do go with a PC based laptop and choose one of those, I'm probably going to "downgrade" to Windows 2000 Pro.
Does OS installation go basically the same on a laptop, as it does with a desktop? I've done desktop installations to the point where I can do it blindfolded, but I have very little experience with laptops.
Hopefully I can just stick the cd in, reformat, partition, and install.
it should be the same.
His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
Yep!Originally Posted by mrtristan
Basicly you´re right. However you do need to be aware of some drivers.
Make sure you get them from the web ( or from the CD before ).
The CD drive will normally be recognised without issues. So will the onboard video card.
the external ports (like S-video out etc.) may need the correct video driver but that´s a problem afterwards.
Same goes for the PCMCIA slots on the side Wether it´s type I or II. They do need specific drivers.
Give us a shout if you run into probs. -
Yea cut and dry, but if you already own 2000 make them throw in PRO and see if you like it. Home sucks but I like Pro and it is stable as hell. For the money you’re putting out for a new notebook you should be able to barter a little.
Good Luck
"Now that I think of it I would like a new notebook also" What are you looking into getting?
Dd(;-{> Dd
Strength and Honor
www.dvd9to5.com
www.dvd9to5.com/forum/
"For every moment of truth there's confusion in life"
Black Sabbath/Ronnie James Dio -
Originally Posted by Doggiedaddy
Comment: If you get XP Pro on the box, you have the right to downgrade to W2K if you decide not to like it that much :P
And if I can add :P Get the new IBM Thinkpad T40 or R40 they rock :P (got the T30 myself) -
Try to get Centrino Technology if your going with INTEL.
And dont forget to check out AMD. But I agree that you should change the O.S. Home sucks ass and Pro is the way to go... while i still prefere to stick with 2k instead of XP because of stability and just plain looks, Ive never been able to get used to the XP gui. -
Originally Posted by WeedVender
note: Turn the GUI off :P -
toooooooooooooooooooooooooooo
Lazy.......................Next Generation Classic......
Mpeg-4 stutter freeze on laptop 1, laptop 2 plays fine- why?
By sevenofone in forum Software PlayingReplies: 1Last Post: 8th Apr 2011, 17:15 -
Installation error
By johnsonk in forum ffmpegX general discussionReplies: 2Last Post: 14th Aug 2009, 12:05 -
Formatting laptop, how do i know if a laptop has wifi capabilities?
By ricardouk in forum ComputerReplies: 8Last Post: 21st Nov 2008, 10:24 -
DVDs work in desktop PC but not in laptop - previously worked in laptop
By Brent Jewell in forum Newbie / General discussionsReplies: 3Last Post: 6th Nov 2008, 20:40 -
using second laptop as a video in from laptop with broken display
By joycefitz in forum Newbie / General discussionsReplies: 4Last Post: 19th May 2008, 00:56
