I have made several SVCDs and I am trying to make copies of them and having no luck. If I just try to use CDRWIN to make an image of the SVCD it fails. If I then just copy the MPEG2 file to the HDD that works (I can play it using WinDVD) but when I try to load it in TSCV and try to create a .bin file I get an error ( ...this looks like a RIFF header but a plain multiplexed program stream was required.). If I try to multiplex with TMPGENc it only gets about 1/7 of the way through and crashes and gives "16 s packets cause buffer underflow The MPEG file might cause error when played".
<font size=-1>[ This Message was edited by: lemmy999 on 2001-09-21 21:24:40 ]</font>
<font size=-1>[ This Message was edited by: lemmy999 on 2001-09-21 21:25:05 ]</font>
I just use Nero's CD Copy, never had a problem. So yes, it is possible.
lemmy999,
You may have a few unrecoverable errors on your disc. If you have problems with other CD copying proggies, you may have more luck with the Blindread.
Regards.
Michael Tam
w: Morsels of Evidence -
I finally got it to work using CloneCD but while making an image it failed to read secotrs 6497 and 79797. It then failed to write in RAW write mode. I changed it to SAO mode and it worked and the new SVCD seemed to play ok. What is causing these weird problems? Is it my CD-RW drive doing a poor job reading, the CD-RW drive did a poor job writing the original SVCD, or the media sux? I have 30 SVCDs that are all the same media (memorex 80 minute) and written with the same drive. Thanks for the responses. BTW, I NERO and CDRWIN would not work.
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
well, just strip off the RIFF wrapping, by running it through a cdxa2mpeg like tool...
just in case you want to see some c source, see
http://vcdimager.hvrlab.org/pub/vcdimager/contribs/cdxa2mpeg.c
this should be adaptable quite easy to compile under windows... it's mostly ANSI C ...
Impossible to copy dvd?
By tomkat in forum DVD RippingReplies: 21Last Post: 20th Mar 2010, 08:10 -
AVCHD MTS numbering restarts at 0, impossible to copy to the same folder.
By cheerful in forum Newbie / General discussionsReplies: 1Last Post: 16th Jan 2010, 23:11 -
16:9 avi to 16:9 wmv, seems impossible to do?!
By Fking in forum Newbie / General discussionsReplies: 5Last Post: 27th May 2008, 00:27 -
Converting to any format is impossible.
By pownager704 in forum Video ConversionReplies: 3Last Post: 19th Apr 2008, 11:07 -
Impossible to capture stream
By hauk in forum Newbie / General discussionsReplies: 1Last Post: 11th Sep 2007, 02:12
