I know this may sound dumb, but here we go. I have a movie on svcd. The problem is, that it is on 3 cd-r. I want to burn it onto a DVD. And I do have a DVD burner. If one of the steps requires me saving the cd's onto my hardrive, could you please try to tell me how to do that (the part that sounds dumb), I've never done this before. Thanks in advance
check out svcd2dvd
http://www.alternativemallorca.com/SVCD2DVDMPG/Help/GettingStarted+.aspx -
I went to the website, but I couldnt figure out how to rip (extract) the movie off of the CD
Originally Posted by Mont
All-In-One guide, VCD or SVCD to DVDR/W with SVCD2DVDMPG+
This guide explains how to put your SVCDs or VCDs or mix them on a DVD-+R/W without reconverting the video. You can also mix NTSC and PAL on same DVDR. You can put about 450 minutes of VCD video and about 300 minutes of SVCD video on one DVDR. In this example I will put one 3 CDs SVCD and one 2 CDS VCD on one DVDR. Before you try this it is recommended that you try DVD-VCD or DVD-SVCD on your DVD Player to see that it works, download samples here and read here how to burn with CopytoDVD.
https://www.videohelp.com/forum/userguides/159399.php -
I used the all in one guide, and I'm kind of stuck at the beginning. I did step 3 and extracted the files. Then it says "Move all MPG (or CUE/BIN files) to one folder. " I interpreted that as just extracting them all into the same folder. So I sent them to My Documents/DVD. Then the next step says "1. Name them in the order you want them on the DVD, like svcdcd1.mpg, svcdcd2.mpg, svcdcd3.mpg, vcdcd1, vcdcd2 and so on (name the bin files to .bin instead of mpg). " I dont think I did this right. Can you explain how to do this. Also, the version on the guide of SVCD2DVDMPG+ is v1.0. The version I downloaded is v1.1, and it doesnt have the same options, what would I need to adjust or change here? Thanks in advance
not sure about the changesOriginally Posted by Mont
Try the new SVD2MPGDVD forum
https://www.videohelp.com/forum/viewforum.php?f=37
How to convert FLV videos and resize them to convert them to AVI
By zikegi in forum Video ConversionReplies: 2Last Post: 17th Sep 2011, 23:06 -
Convert AVI (miniDV) to MKV/MP4, large files only convert partially
By Video Eddie in forum Video ConversionReplies: 0Last Post: 3rd Jan 2011, 05:44 -
To convert or not to convert a pal dvd
By nls8520 in forum Video ConversionReplies: 1Last Post: 22nd Jun 2010, 01:35
