When I try to convert the audio from 44000 to 48000 (to make DVD compliant as I want to build menus and so forth) on my mpeg files i always get an audio sync problem, the audio gradually gets out of sync. Now I have noticed that when I demux the original mpeg and play the individual files, the audio file time is always shorter than the video time. Although the original mpeg is always in sync. The mpegs are tv caps and I always get this problem. When I load the mpeg up in Vdub, I check out the frame rate menu and it has the option "Change so video and audio durations match" where a new framerate is indicated that is faster than the original 29.970fps, eg 30.033.
Is there any way I can get these files to sync properly?
Fixed it.
You can read my post about it here;
https://www.videohelp.com/forum/viewtopic.php?t=161675
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
Audio video sync problem
By FrankieToh in forum Newbie / General discussionsReplies: 0Last Post: 3rd Dec 2010, 07:53 -
Audio Sync Problem
By lwea2009 in forum Newbie / General discussionsReplies: 8Last Post: 30th May 2009, 15:19 -
out of sync audio problem
By virendra in forum AudioReplies: 2Last Post: 25th Dec 2007, 06:31 -
New (?) audio sync problem
By oldblues in forum ffmpegX general discussionReplies: 3Last Post: 26th Oct 2007, 10:26
