I'm using Power VCR to capture video from a satellite receiver and I've tried several formats to capture with...e.g. DVD and Mpeg2 and Power VCR always makes those capture files around 614 megs each...so I might have 3-7 614 meg fiels...depending on the length of the movie.
How can I make Power VCR capture it a one file only? I can't find any settings to make it do that.
Anyone have a suggestion?
DarkCyber
Results 1 to 9 of 9
you can't. that why i don't use it to capture, even though it's one of the best capturing programs around as far as picture quality
Please change the registry value:
[HKEY_CURRENT_USER Software CyberLinkPowerVCR II]
"MaxRecSizeMB"=dword:00000FA0
if you want 4GB.
Maybe also higher values work. Please be aware of OS limits if you are not using a NTFS formatted hard drive (WIN2000, XP). -
I am using Windows XP Pro with NTFS file system. So, I have to enter a hexidecimal number? Can you give me some numbers for 5 gig and 6 gigs? Or is that to high?
DarkCyber -
how do u get to the registry? i only mess with it once and that was a long time ago
Go to the Start Menu, Run, then type in Regedit, then click OK.
"Don't try to be a great man. Just be a man, and let history make its own judgment."
Zefram Cochrane
2073 -
Decimal to Hex
Use Start, Programs, Accesories, Calculator
Change from Standard to Scientific
Enter the decimal number e.g. 5000 and click Hex. Now you have the Hex value for your desired size. I'm not sure if PowerVCR will accept those. Using it for Cut & Merge there seems to be a limit of about 3GB. -
See this thread for step by step.
https://www.videohelp.com/forum/viewtopic.php?t=141548&highlight=maxrecsizemb -
Damn! You guys are great! Thanks for that hack. That filesize limitation has been driving me nuts lately.
- Styro
Question about new Power supply ?
By VEBouto in forum ComputerReplies: 7Last Post: 8th Oct 2010, 15:36 -
quick question on power of Avisynth script?
By kopmjj in forum RestorationReplies: 4Last Post: 16th Apr 2010, 23:36 -
Power Supply Question
By jjis in forum ComputerReplies: 10Last Post: 6th Nov 2009, 08:35 -
Windows Power Management Question
By NBninja8 in forum ComputerReplies: 5Last Post: 12th Jan 2008, 23:51 -
question about Power DVD DX
By Bamahusker in forum Newbie / General discussionsReplies: 5Last Post: 3rd Jul 2007, 18:35
