ive just bought a new multiregional player with a built in PAL- NTSC converter which has enabled me to start purchasing region 1 discs. I wanted to play them on my old region 2 machine too, so i set about trying to convert from NTSC to PAL.
After first ripping the movie vobs with DVD Decrypter, I created the d2v and AC3 files with DVD2AVI and opened them up in TMPGenc. I have tried changing the settings in numerous different ways, but my resultant mpg file always seems to be jerky on playback, both on my pc and on my standalone player.
I just want to to know if its possible to get a converted file that plays smoothly, or am i looking for an answer that doesnt exist? I'm new to this, so be gentle! Am i right in thinking that because i am converting from 29.97 fps to 25 fps, frames are being removed, and hence the jerky playback?
If there is a way around it, id be thankful for some pointers! ive tried several tutorials, but always seem to endup with that jerkiness!
I just became addicted to DVD Shrink. It lets you choose any and all regions before writing your new DVD. Just a thought.
Hello. -
thats one way (an easy way too)! u can make the backup multiregional, but what if you hav a povvy old tv that doesnt support NTSC?
Plus, as ive been tryin, i just wondered if it was possible.......ima curious so and so!
thanks for the idea tho! -
Yes, you're probably getting jerky conversion because of the frame rate being changed. Most NTSC DVDs are actually encoded at 24fps (FILM), so you can use Force FILM in DVD2AVI. To get smooth playback converting 24fps to 25fps you can use a short avisynth script with assumefps() to just change the playback speed instead of adding/removing frames. You'll need to adjust the audio length to match, besweet can do that.
There's a guide talking about this on this site, but I don't remember exactly where it is.... -
Sterno's right. There is a guide for framerate conversion. Click here. Here is the excerpt:
1b. Frameserve with Avisynth
Avisource("c:..dir..filename.avi")#PALsource
#BilinearResize(448,254,1,0,638,272)
#AddBorders(16,113,16,113)
AssumeFPS(23.976)
Avisource("c:..dir..filename.avi")#NTSCsource
#BilinearResize(448,306,1,0,638,272)
#AddBorders(16,135,16,135)
AssumeFPS(25)
If the source is MPEG-1 use DirectShowSource instead of AviSource.
If the source is MPEG-2, create a DVD2AVI project and get the mpeg2dec plugin for Avisynth.
LoadPlugin("c:..dir..mpeg2dec.dll")
mpeg2source("c:..dir..filename.d2v")
AssumeFPS(23.976)Hello.
PAL video on NTSC HD TV Best motion Playback
By Deter in forum RestorationReplies: 7Last Post: 25th Aug 2011, 05:34 -
NTSC -> PAL on NTSC Playback VCR
By Cyberrock in forum Capturing and VCRReplies: 21Last Post: 28th Sep 2010, 03:52 -
Can the JVC HR-DVS1 playback both NTSC and PAL videos
By ramrod1234 in forum Capturing and VCRReplies: 7Last Post: 11th Oct 2009, 09:43 -
PAL Video Cassette Recorder or [Multisystem VCR] for PAL->NTSC playback
By quantass in forum Newbie / General discussionsReplies: 10Last Post: 12th Dec 2008, 13:47 -
NTSC Playback on PAL TV. Only 525 lines being displayed.
By mr_mop in forum DVD & Blu-ray RecordersReplies: 3Last Post: 21st Sep 2007, 08:06
