hi there everybody,
i´m trying to give my first footsteps with Dvd Maestro and i have the following problem:
i´m trying to merge 2 video files ( m2v ) and their respective audio files ( ac3 ).
dvd maestro allows me to put the 2 video files one followed by the other but it doesnt allow me to do the same with the audio files.
One has to create a sync audio file ( whatever that is ) but when i assign each audio file to its respective video file and order the create new audio file when the process reaches 95% it hangs the dvd maestro.
if i invert the audio files ( not wanted obviously but as a experience ) it no longer hangs!
can anyone tell me where is the problem? or what am i doing wrong?
is the problem on the video files offset timecode? how can i reset the offset timecode in both video files? better yet for what is the offset for?
i m lost in here, i was almost getting to compile a 2 part dvd concert into one single dvd, which is more pratical.
thanks advance for any help
best regards
how long do you actually let it hang ?
mine always hangs at 95% for a good 2 minutes, i believe it is at that point that it is syncronising the audio, the 95% is compiling again.
is your files named the same 1.m2v, 1.ac3 etc.
thingimijig. -
hi,
well i let it hang for a while, almost 20 min.
i´ve tried something that was importing the ALL.ac3 and let it be parsed and voilá it gives an error when parsing :
Cannot locate a frame SYNC word at an expected byte offset.
Data might be corrupted.
(0xc1070042)
I´ve ripped inicially the ac3 files with smart ripper but after that i tried with decrypter and it no longer hangs when creating thw sync audio file.
the only thing i dont understand is how 2 programs rip 2 different files, always with frames differences when compared with the video files.
smart ripper had less frames than video file giving a parsing error when importing the asset into maestro.
decrypter had more frames than video file dont giving the parsing error.
the parsing error is : a not complete frame is found?!
do you know any way to change the offset time off m2v files?
thanks in advance
best regards -
you can change the offset time of the ac3 file by sliding it on the time line ..
you cant have the video start later than the audio - so there is no offset -- but you can trim the end of it in maestro ..
Problems with chapters in DVD authoring/audio temporarily off-sync
By nocomments87 in forum Authoring (DVD)Replies: 7Last Post: 9th Nov 2011, 08:44 -
Audio out of sync after DVD authoring
By dexter30 in forum Authoring (DVD)Replies: 7Last Post: 29th Oct 2010, 18:27 -
audio sync problem creating DVD from AVI files
By EtherJones in forum Authoring (DVD)Replies: 2Last Post: 8th Jun 2010, 10:12 -
StaxRip audio sync problem creating MKV files
By ejai in forum DVD RippingReplies: 0Last Post: 24th Apr 2009, 15:16 -
Audio Sync Problem, Repairing and AVI File?
By JerryRecords in forum AudioReplies: 1Last Post: 4th Dec 2008, 23:38
