I have a creative labs digital vcr capture card. I'm not sure how to set up my recording so the audio is in MPEG Audio format. Here's what I am doing:
I am trying to record some shows and then ultimately burn them onto a dvd for my kids to watch.
I record the shows using digital vcr. I then use the export program that came with digital vcr to export the shows to MPEG2 format. I understand this format is not recognizable to most programs, so I am using DVD2AVI to get the files into a format that tmpeng can recognize.
My problem is this. When I open some of the exported shows in DVD2AVI and look at the audio format it says "Linear PCM". Some of the shows say "MPEG Audio". Any of them that show MPEG Audio work great for me. The ones that say Linear PCM do not work. Once I run them through DVD2AVI and try to play the mp3 file that is created, all I hear is static.
How do I either set up digital vcr to only use MPEG Audio or how do I get those files that use Linear PCM to work in DVD2AVI?
Please help. I am very new to all of this, so please be specific in any suggestions you have. I would appreciate any and all help.
Colleen Dixon
Results 1 to 1 of 1
Trouble hooking up VCR
By chathamsue in forum MediaReplies: 11Last Post: 28th May 2011, 23:45 -
Trouble uploading comcorder tapes for converting to digital
By LeAnnaB in forum Newbie / General discussionsReplies: 0Last Post: 30th Dec 2010, 04:09 -
Trouble capturing from VCR, completely stumped
By mikeveli20 in forum Capturing and VCRReplies: 12Last Post: 25th Oct 2009, 11:00 -
Trouble converting VOB to AVI using Handbrake (audio issue)
By binvisions in forum Video ConversionReplies: 1Last Post: 1st Aug 2009, 04:28 -
Help deciding on Hi8mm VCR or Digital 8 Camcorder
By k2skier in forum Newbie / General discussionsReplies: 8Last Post: 12th Dec 2008, 01:52
