Results 1 to 13 of 13
    Land Of The Midnight Sun
    I recently purchased the Panasonic DMR E50 region2 Pal version. It's working great and I'm very pleased with it.
    The only problem I have is to play the DVD-R discs on my computer DVD-ROM player (and yes I have "Finalized" the disc). I have tried 5 different DVD-ROM players on different computers and all fail to read the disc. Anyone else having this problem?
    The Disc is playing perfect on several different desktop DVD players.
    Jan 2002
    I have an E-30 and an HS-2. I just popped a DVD into my burner with 5 3s Company episodes on it. It works fine. I think it was recorded on the HS-2.
    I can't try the disc on my DVD Rom because it's not hooked up. If I want to use it, I have to pull my CD burner beacause my IDE channels are full.
    Sorry I couldn't be of more help.
  3. I have the E30 NTSC and don't have problems playing the discs on DVD-ROM or stand along players.
  4. Have a DMR-E50EG Region2 Pal/NTSC.
    Record on Princo1x in SP and FR Mode in PAL
    and play the DVDs on my
    Pioneer DVD-Rom DVD-117 and my
    Pioneer DVD-RW DVR-105.
    Thanks for your replays!
    Here is some more info.
    I have two different drives connected to my Power Mac 1.3Ghz, one Pioneer DVD-RW DVR-105 (internal) and one Matshita (Panasonic) CW8571 Combo-drive connected via FireWire.
    No one of this drives can read the disc produced by the DMR E50. The disk mounts on the desktop named as "DVD_VIDEO_RECORDER" and when I open the "Get Info" window it says "Capacity 2,9Gb" "Available: Zero KB " Used 2,9Gb on disk (3 121 510 400 bytes) If I double-click on the disc there is no folders or contents on it, I guess it should have been a "VIDEO_TS" folder and a AUDIO_TS" if everything was okay.
    I've tried different discs produced by the DMR E50 on my computer and also on 4 different Windows machines running Windows XP. When I put the disc in a DVD-ROM drive running XP the following message appears. "The disc is unreadable"
    Still works flawlessly on any desktop DVD player.
    Strange....... well I guess I'll have to return the unit for new one.
    BTW. I'm using Memorex DVD-R discs for my recordings.
    Feb 2003
    U.S.A.
    Many people have complained about Memorex discs on Panasonic recorders. I would try using another brand. The discs made in Japan are always good, as well as Mitsui & Fuji. (As far as I'm concerned, Memorex has NEVER made anything I would call a great product - and that includes audio and video tape too.)
  7. Make sure you set Hybrid VBR to off, that should help with compatibility with both computer drives and other DVD players.
    There is two options for the VBR "Automatic or Fixed" I have used the automatic setting which is the default setting.
    I will try the Fixed option and see if it make any difference.
    The Panasonic 4x DVD-R disc that came with E50 also fales on all the DVD-ROM players, so I don't think this is a disc disc problem.
  9. BTW there is no AUDIO_TS folder made by the E-50.
    There only a VIDEO_TS folder which include the files.
    When the DVD_VIDEO_RECORDER Disc has no folder there is a Writing (E-50) or Reading (DVD_ROM) Problem.
    There are no difference between FR-Mode and Fix bitrates in reading disc, maybe some freezes when the bitrates are too high for some standalone player.
    I tested the "Fixed Mode" with no success still not readable on my Mac DVD-ROM drives. Also tried it on some Windows machines with no luck.
    Well seems like I have to return the unit for a new one.
    PS: Contacted Panasonic support here in Sweden today and they where not able to help me. They told me that discs burned with E50 should work on any newer DVD-ROM drive but could not give me any suggestion more than that I have to return the unit.
    BTW: the Panny support center here in Sweden is a shame only open 2 hours a day!
    Thanks for all help and suggestions!
  11. No problems here, but I have only recorded one DVD-R on the E-50! I prefer to use RAM then edit, remove to the PC and make menus etc then burn. The one DVD-R (Samgsung Be-ALL) disk I have made works fine on my PC DVD-ROM.
    Panasonic E-50
    Panasonic SW-9581
    NEC DVD-ROM
  12. I can't get dvd-ram disc made from my E50 to play on my computer. It just won't recognise them.. And my dvd drive is a panasonic lf d311.
    Haven't had the balls to waste a dvd-r trying it out, but I guess I'll have to
  13. I've tested the Panasonic DMR-E30 extensively.
    Here were the conclusions:
    1. The DVD-RAM discs produced by this unit play in all DVD-RAM drives I have tested, including the Panasonic SW-9571 and the Panasonic LF-D311;
    2. The DVD-R discs produced by this unit play in virtually all stand alone DVD player/recorders;
    3. The DVD-R discs produced by this unit play only in *some* computer DVD-ROM drives - 'spotty' compatibility in other words;
    We had the most difficulties with 3rd party, add-in drives in our tests.
    Hi-Val add-in: No
    Creative Labs add-in: No
    DVS add-in: No
    Samsung OEM: Yes
    Note: The same poor compatibility was exhibited by the DVD+R disc we tested from the stand alone player/recorder from Philips... the DVDR985.
    4. We tested the Pioneer DVR-7000 last and the DVD-R discs produced by this unit played in all computer DVD-ROM drives tested.
    This is not a format issue, folks.
    This is an engineering issue.
    Jerry Jones
    http://www.jonesgroup.net
