CAN ANYBODY HELP WITH THIS
THANKS
use clean source
use noise filtering (spatial and temporal)
use "macro-block reduction" option
use higher bitrate -
patrickm,
I've never seen a "macro-block reduction" option before. Which encoder is that?
Most lay people use the term "macroblock" to refer to block noise, like the author of this thread did. (That's fine with me.) But that definition conflicts with the technical meaning of "macroblock", so I find it surprising that the author of an mpeg encoder would offer an option by that name.
Just wondering if the "macro-block reduction" option might be intended for something else. Or is that the actual name?
How to avoid Generation Loss as much as possible?
By Undead Sega in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 12Last Post: 16th Sep 2008, 18:51 -
What is PVOP and how do I avoid it?
By Strumpah in forum EditingReplies: 4Last Post: 12th May 2008, 19:04 -
How do you avoid banding?
By zanos in forum MediaReplies: 3Last Post: 13th Mar 2008, 22:57 -
director commentary.How do you avoid it?
By Dr.Gee in forum Newbie / General discussionsReplies: 6Last Post: 2nd Nov 2007, 09:43
