I don't have crappy hardware, but I notice that VCDs I make look much better on tv from a player than on my computer screen using WMP. Does anyone know any good PC VCD/SVCD player that gives you the TV look instead of the pixelated noise filled crappy PC look?? My desktop resolution is 1024 X 768, and I have a GeForce4 MX 440 128 AGP video cad with an envision En-775e True-Flat CRT with .21 mm HDP. So far Zoom Player gives me the best results for VCD, but noise is still rather noticable, as is pixelation. I use Power DVD for SVCD/CVD, but for some reason the aduio always is too low sounding, Any help there?
Results 1 to 9 of 9
A VCD will usually look better on a TV than a PC especially if you use WMP.Use Cyberlink PowerDVD,WinDVD or I-VCD player(free in Tools) to view on PC.
also, don't resize it if you play it in powerdvd. let it play in a small window.
His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
the computer screen has better qulity then the tv .
thats why it looks "better" on a tv (bigger dots = less qulity),
the comuter screen is much sharper, so you can see every glitch
in the video.
i dont think a different player will do the trick, but it might help a bit.HELL AINT A BAD PLACE TO BE -
All the players are pretty much the same.
WMP is as good as any.
If you want to try some others ...go here:
http://www.digital-digest.com/dvd/downloads/all_downloads.html#playback
or here:
https://www.videohelp.com/tools#players"Today is only yesterdays tomorrow" -
WMP version 7+ does not understand the DAR tags --> so your video looking slightly off.
I suggest the software DVD players as the others have suggested or go back to using WMP6.x
Regards.Michael Tam
w: Morsels of Evidence -
I prefer WinDVD, it plays Audio CD's, DVD, Divx, and VCD's. If you get WinDVD Recorder, you can even watch/capture from a tuner card.
Its amazing how 1 program can do more than all of Ati Multimedia center -
lower your computer screen resolution to 800x600 when u watch vcds
Heavensent hit it on the nose
Recommend DVD Player for old Gateway computer
By WannaWatch in forum ComputerReplies: 1Last Post: 24th Aug 2010, 18:56 -
Cant read DVD on computer....but can on player!!
By DrRaven in forum Newbie / General discussionsReplies: 1Last Post: 23rd Aug 2009, 04:02 -
interlaced player for computer monitor
By CuriousYellow in forum Software PlayingReplies: 1Last Post: 13th May 2009, 13:41 -
Subs sync ok on computer but off in player !
By dexterdoo in forum SubtitleReplies: 1Last Post: 15th Jan 2008, 14:05 -
LP player that lets you record to computer
By Tearren in forum Off topicReplies: 3Last Post: 30th Dec 2007, 04:40
