Hi fellas. ill get straight to the core of the problem :
I added 2mpeg files to vcdeasy 1.15 with entry points. Vcdeasy scans the files ok but when it begins to write the bin file i get a little window that pops up saying the xml file was created successfully but there was an error with vcdxbuild and as such didnt write the bin?
the last few lines of the log are as follows :
writing track 1 (ISO9660)...
'update scan offsets' option enabled for the following tracks!
writing track 2, MPEG2, NTSC UNKNOWN (480x480/23.98fps), audio[0]: l2/48.0kHz/224kbps/stereo ...
3 [main] vcdxbuild 1724 handle_exceptions: Exception: STATUS_ACCESS_VIOLATION
49387 [main] vcdxbuild 1724 open_stackdumpfile: Dumping stack trace to vcdxbuild.exe.stackdump
can anyone help me to fix this? thanks!![]()
I think it didnt write the bin through vcdimager.
Try demuxing and muxing again."Today is only yesterdays tomorrow"
Administrator Privilege to Run VCDEasy
By asifmcp in forum VCDEasy GeneralReplies: 2Last Post: 8th Jan 2011, 05:48 -
Burning with VcdEasy
By gkma01 in forum Authoring (VCD/SVCD)Replies: 6Last Post: 19th Sep 2008, 21:00 -
Problem with creaing Menu in VCDEasy
By haris in forum Authoring (VCD/SVCD)Replies: 5Last Post: 16th Mar 2008, 09:17 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 17:41 -
How will I make an AVCD using VCDEasy?
By zeldAIS in forum VCDEasy GeneralReplies: 1Last Post: 4th Aug 2007, 16:13
