How to burn a .bin when the .cue is missing?
I have the .bin file, but the .cue file is missing, and everytime i have tried to burn it with NERO, it just doesnt seem to work correctly.
Any input would be helpfull
thanks,
papaholmz
Did you try irc? #cuevault on Efnet?
If its a bin of a movie you could extract the mpeg from the bin using Isobuster then remake a whole new bin & cue from the mpeg with VCDEasy.
Or...some people have found this little program useful.. it'll simply make a cue file from the bin for you
http://www.dslreports.com/r0/download/360252~1e45059000cfc371c157f544cc5aef07/MakeCue.zip -
I think you need to have both .CUE and .BIN files to correctly burn a disc.
Check this forum topic for more info:
Making .cue files
https://www.videohelp.com/forum/viewtopic.php?t=164034&start=0&postdays=0&postorder=asc -
Using Nero simply go to burn image and then tell it to look at all files. Then click on the .bin and burn it. If it is a video CD (VCD, SVCD) then you need to change the burn to mode2. If it is data, then most likely it will be mode1. This method has not failed me yet.
Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they? -
I'd read petesimon's links. bin2iso seems to work for me. Just make sure that your bin and the created cue file are in the same directory, preferably something short like the c:\ directory for the sake of keeping the command lines simple. Load up the cue and burn in Nero.
Turn your head and cough.
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 16:25 -
How to burn a .iso/bin,cue with nero
By Chupes in forum User guidesReplies: 5Last Post: 9th Sep 2009, 21:33 -
question how to burn bin/cue file to DVD disk
By jimdagys in forum Newbie / General discussionsReplies: 9Last Post: 17th May 2008, 12:58 -
cue,bin converting to dvd?
By zziem in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2007, 11:36 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 22:29
