Hello,
I've looked and searched for info on DVD2MPEG but I.m not finding any software that will actualy create a MPEG file from a VOB file....
I don't want to re-encode into VCD or DivX or anything.
Here's what I'm trying to do.
I created DVDs from last years vacation footage.
Now I want to do some nicer menus and better editing of the footage.
I don't have the AVIs and the tapes are over-written.
I want to pull the MPEGs (with MPEG audio) out of the VOBs and use Womble to cut and splice the MPEG from there....
can you point me in the right direction?
Vob's are mpg2 files. I have used TMPEG's MpegTools to convert vob files into mpg files. It will preserve their original video and audio quality. What kind of audio is on your vob's?
wulf is right, use Tmpgenc's mpeg-tools, simple demultiplex to get seperate mpeg-2 video and audio streams. You can then use the simple multiplex to put them back together into a simple mpeg program stream if you wish. A VOB is essentially an mpeg-2 program stream with extra info added.
Or VOBRator. Or VOBEdit.
Essentially, any program that can demux your VOBs into their component parts. VOBRator seems the easiest of all of these to me, but they all work."Like a knife, he cuts through life, like every day's his last" -- Mr. Kiss Kiss Bang Bang -
That's simple...
Just Like ME!
Thanks guys,
gNOMEintheRedHat
Extract frame from VOB file.
By kwazi in forum ProgrammingReplies: 8Last Post: 17th May 2013, 17:24 -
How to Extract Subtitles from a VOB File?
By skorpinok in forum Video ConversionReplies: 2Last Post: 16th Oct 2011, 18:35 -
Trying to extract VOB file with Isobuster, nothing happens?
By dai3504 in forum DVD RippingReplies: 2Last Post: 8th May 2011, 10:42 -
extract subtitles from .VOB file
By avextraxjp in forum Newbie / General discussionsReplies: 2Last Post: 10th May 2010, 12:19 -
How can I extract chapters from VOB file?
By SubFlow in forum EditingReplies: 1Last Post: 18th Jun 2008, 03:49
