Hello
first, i want to apologise if this is a repeat of another topic....
My problem is:
My friend loaned to me a dvd from Region 1 (and it only has english subtitles) and i as a portuguese and living in portugal, would very much like to add portugues subtitles to the dvd.
I ussualy use DVDDecrypter and then dvd2one.
Is there anyway that i can insert a new subtitle ? How ?
can i add a subtitle like the ones that are used in divx ? do i have to translate the english subtitles in the disc to portugues and insert then in the new dvd ?
Can some please help me ????? Please !!!?!!!
..... Or give an address with a guide ????? Please !!!!
Many Thanks
Sorry I don't there is a way to add Portuguese subtittles, unless they are encluded in th dvd. The only way I can think of is to re-auther dvd and make your own subtittles. I can't help you with that though.
Hey, I was born in Portugal.Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
You might want to check this out http://www.eswat.demon.co.uk/substation.html
Hope that helps.Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
Changing dvd subtitles requires a lot of work.
I would use this method:
Rip the english subtitles to a text format, with subrip or some other subtitle dvd ripper.
Rip the video(mpeg2) and audio stream(ac3/dts) from the dvd with for example smartripper or dvddecrypter.
Translate the subtitles to portugise(you could try search for portuguse subtitles for just that movie, www.divxsubtitles.net or some other subtitles site....).
Use ifoedit authoring to reauthor the dvds with new subtitles. Before you must convert the subs to ifo sup format with dvd subtitle converter(from www.doom9.org). Then add the video, audio and subtitles in ifoedit author and author. You will lose the menu and the extra materials.
https://www.videohelp.com/forum/userguides/120013.php
I have not tested this method yet...
How to add SRT subtitles to a DVD?
By sldvd in forum Newbie / General discussionsReplies: 3Last Post: 3rd Aug 2011, 13:39 -
Is it possible to remove subtitles from one dvd and add them to another?
By nouseforaname in forum EditingReplies: 2Last Post: 16th Jul 2010, 15:54 -
How to add Subtitles to original DVD whitout loosing original subtitles ?
By Chainsaw_1 in forum Newbie / General discussionsReplies: 2Last Post: 6th Jan 2010, 12:52 -
Add subtitles to DVD using DVDSubEdit
By marco_silva85 in forum SubtitleReplies: 3Last Post: 19th Jun 2008, 21:57 -
How do I add new subtitles to a existing DVD?
By Baldrick in forum SubtitleReplies: 7Last Post: 14th May 2008, 09:42
