I have decripted my dvd on my PC(don't have the original anymore).
Is there a way that i can split these files with dvdxcopy on 2 DVDs without any lose. How to make a fake DVD with the files that i have on my PC so dvdxcopy will recognize it and make a copy.
Thanks for the help.
Beno.
you could create a virtual dvd using software such as alcohol 120%
I have personally never done this, so I do not know if this will trick dvdxcopy. Might be worth a try.
Good luck
