ok ive seen there are many requests similer to this but i cant make sence of them. Here is my problem i have a divx file lests say gone in sixty seconds dvdrip divx its a 700 or so mb file so i load up TMPGEnc
(ok now first off when i encode i do non standered svcds and what i mean by this is mpeg layer 1 non standered svcd and than burn as vcd with nero basicly the header trick but i reencode the actual movie) ok when i load the divx into TMPGEnc plus registered and do this it encodes fine so i burn than play and it goes out of sync like 5 minutes into the movie so i use a resync trick i leared by hitting the rewind button for like 1 seccond than hitting play it usually syncs back up... now my question is why is it going out of sync like every 10 minutes and is there anything i can change in TMPGEnc to prevent it from going out of sync (yes i have to encode as non standered layer 1 svcd cause my dvdplayer doesnt support standered stuff) any easy methods to help ?????????
Its always funny when it happens to someone else
Well, if it's one thing that's marks a CD as SVCD like, is that it's mpeg 2. Mpeg 1 would be VCD - specially as you author as VCD...i do non standered svcds and what i mean by this is mpeg layer 1
The header trick involves encoding to SVCD standard, while multiplexing as VCD (non standard) mpeg.
Your sync problem is probably due to errors in the source AVI. Use VirtualDub and scan for bad frames. Then save out the AVI again using direct stream copy. Use this copy as source for, or frame serve it to TMPGEnc
/Mats -
ok i have vdub open and the divx file loaded now how do i scan for bad frams do i go to frameserving or what ?
Its always funny when it happens to someone else -
Video -> scan video stream for errors.
i use 1.4c and i dont have that option should i upgrade to the new version ? i got the mp3 addond thing to scan for bad frames and my movie checks out fine so i guess its ok im gonna encode it and see
It's definately there in 1.4.13 - last option in the Video menu.
Even if the scan reports nothing, I've found that saving out a second copy and using that will help. I had this AVI recently, that kept crashing VDub (when frame serving) at about 16 minutes. Scanning reported nothing, but when I tried to play the AVI, VDub couldn't play a couple of 100 of frames at that point. So, I saved a new copy after scanning, and there was no problems after that.
/Mats
Command line method to convert MPEG-2 to Divx Home Theater Profile
By CLIjunkie in forum Video ConversionReplies: 15Last Post: 6th May 2008, 22:22 -
Best conversion method for mass DVD to DivX
By spidey in forum Video ConversionReplies: 3Last Post: 1st May 2008, 09:29 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07 -
What is the easiest method to add intro clip on DIVX ?
By rob3rtz in forum Newbie / General discussionsReplies: 3Last Post: 7th Oct 2007, 05:35 -
Best capture card and method for VHS to DiVX?
By Vantage in forum Capturing and VCRReplies: 9Last Post: 4th Aug 2007, 15:11
