Ive had very bad experiences and still havent been able to authour a dvd yet , Ive heard talk of Maestro...Got it but i have an error message saying"realtime preview not enabled because no decoders have been detected, and also, how the heck to you chose a movie to burn much less anything else![]()
Results 1 to 14 of 14
did you read the manual?
His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
yeah, that would be depressing to spend that much on software and not be able to figure out how to use it
you dont burn with maestro unless you have a pioneer a201 burner or you can make a DLT tape for mastering purposes .. (or make a img file is a good plan)
i suggest you read through the 350 page manual first and practise making up some dvd projects .. -- maybe call your dealer for some training .. -
also -- for real time preview .. you need cinemaster decoder drivers or the cinemaster hardware decoder
the card came with the program -- the software is no longer made though there are some variances on it that work .. -
Originally Posted by txpharoah
......hmmm but most CCE users are legit RIGHT !
I'd believe a person buying CCE before I would see somebody buying Maestro, not to mention that it's no longer available for purchase (and hasn't been for quite some time). If you use these program commercially, the cost isn't really all that bad. I own too many programs myself.Originally Posted by holisticI'm not online anymore. Ask BALDRICK, LORDSMURF or SATSTORM for help. PM's are ignored.
Lucky you...
For people like me (salary: 600 euros) the solution is only one: TMPG Author. The only alternative: the -still buggy- DVDlab. -
almost always legal copy on ebay -- i see only one todayOriginally Posted by txpharoah
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=3027597982&category=21166 -
Gentlemen, forgive my cynicism, but anyone who could afford to drop $3000 + on a piece of software should be able to :
1.spell (read some CCE forum questions one day)
2.use the above to READ the “F’n” USER MANUAL
As for using it to ‘back up’ DVD’s ………………Damm if I had $3000+ to blow it wouldn't be used for “backing up DVD’s”
$3000 buys a whole lot of originals.
well i cant spell very well at all- but then again i dont use maestro to back up dvd's -- but to create them in the first place so you people can back them up ..
You go girl !!!Originally Posted by BJ_M
Anyway, back to the post:
Mayhem- If you "lost" (wink,wink) the manual, or even if you have it, there are tons of excellent guides on this site and "Doom 9" that explain (in great detail) how to author a DVD using DVD Maestro!
If you go under "How To" and then "DVD RIP" and choose the "DVD 2 DVDR for Dummies" guide (not to insinuate anything), you will find a simple example of an authoring process with Maestro. You can also search the other guides (some dedicated entirely to DVD Maestro) and find even more info on settings and uses. As far as the "Realtime preview" not enabled, it's not a huge deal. It just means you can't actually watch (preview) the movie before you compile it, but you can still see all your chapter points, and the program still functions normally otherwise!
Good Luck
The best way I found for single PGC titles, for me anyway, Trilight has some very good stuff. He also has other more advanced guides for multiple PGC titles but with scenarist. A little overwhelming at first but after a few projects it should all fall in place. Are you doing DV because this a hard way just for BU your DVDs, with things like IC7 and others out there?
Good Luck
Dd
http://www.doom9.org/index.html?/mpg/maestro2.htm(;-{> Dd
Strength and Honor
www.dvd9to5.com
www.dvd9to5.com/forum/
"For every moment of truth there's confusion in life"
Black Sabbath/Ronnie James Dio
NovaMate NovaTrol 2 TBC - How the heck do I use it??
By jbd5010 in forum Capturing and VCRReplies: 4Last Post: 3rd Feb 2012, 17:04 -
DVD Maestro Compilation error
By MJPro-Tester in forum Authoring (DVD)Replies: 1Last Post: 21st Apr 2010, 04:22 -
What the heck is Unreferenced Material ? ? ?
By nhbfan12345 in forum Authoring (DVD)Replies: 1Last Post: 6th Nov 2008, 17:01 -
How the heck did they do that SuperBowl eTrade ad?
By ahhaa in forum ComputerReplies: 6Last Post: 5th Feb 2008, 17:08 -
How in the heck do they do it!?!
By proof in forum DVD RippingReplies: 4Last Post: 19th Sep 2007, 15:37
