  1. Banned
    May 2003
    Dallas
    Is there anyway I can take the folders of a VCD or SVCD and Make them into a VCD or SVCD or Their Own? If there is any possible way let me know, thanks a mil
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Huh? If you want to recreate the mpeg(s), use VCDGear or VCDEasy to extract the .dat and "convert it" to mpg. If that's not what you're after, please explain further!
    /Mats
  3. Banned
    May 2003
    Dallas
    On my upstairs computer, I burned the files out of .bin and .cue to make a SVCD. I did that with Alcohol 120. But my upstairs computer is getting fixed. So I cant get on that computer but I still have this SVCD I made with it. But you know the folders in a VCD; EXT, MPEG2, SVCD. I was wondering if I could make another VCD with these folders? Thanks 8)
  4. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Just do a straight CD copy with whatever software you use. No need to take it apart and put a new one together again...
    /Mats
  5. Banned
    May 2003
    Dallas
    I dont have two drives, but what program would I do a straight cd copy with? And if I wanted to take it aprart, what would I have to do to make a cd?
    MO, US
    Whatever software came with your burner? Nero, Adaptec, BHA, whatever.
    VCDEasy provides a front-end to cdrdao and vcdxrip that can take a finished (S)VCD and extract all the files, as well as producing a vcdimager XML file that can recreate the original disc.
