I have a divx file that is 352x288 and I want to make a vcd... do I need to resize it or does TMPGENC do that automatically?? I live in NorthAmerica.
Also where are the exact instructions on using TMPGENC?
No, you have to do it manually. Go to CONFIGURE and select vcd(if that's what you want) and then resize it to 352x240, standard for vcd.
<font size=-1>[ This Message was edited by: gadget on 2001-09-21 17:51:09 ]</font> -
Are you that I HAVE TO do that for the vcd to play, or is it just to make the viewing a more normal size?
Also, where is this CONFIGURE option in TMPGENC? I don't see anything called that...
Reduce AVi file size
By froggger in forum Newbie / General discussionsReplies: 7Last Post: 9th Feb 2009, 17:58 -
Reencoding to reduce the file size of an AVI (xvid) file
By DVantrease in forum Video ConversionReplies: 7Last Post: 10th Jan 2009, 21:56 -
Decrease the size of an avi file
By mierdatuti in forum Newbie / General discussionsReplies: 3Last Post: 5th Oct 2008, 12:51 -
AVI File Size problem
By prcole18 in forum Capturing and VCRReplies: 5Last Post: 14th Jul 2008, 19:05 -
What AVI File Size Should I Choose
By Dubinvero in forum EditingReplies: 2Last Post: 22nd Sep 2007, 23:05
