Will using the Pioneer fix make the DVD all weird on players that DON'T exhibit this problem, or is it just an extra step that you otherwise would not need to waste time doing?
Basically, I want to burn a DVD... one for me (Pioneer) and another for my friend (Sony). I need the fix, he doesn't. Will the same image work for both of us?
- Gurm
I have a Pioneer 525. I made a test DVD and had several friends try on their:Originally Posted by Gurm
APEX
Sony
Panasonic
NO PROBLEM! -
Thanks. Good to know.
How much longer will it take? I find that it takes anywhere from 30-60 minutes (depending on the number of SVCD's and how I encode the audio) to do it now... the readme says "much longer". Is much longer like 3 hours or like another 30 minutes?
- Gurm -
The one time test that I do remember was for 2 SVCD's converted using the Header Fix to 3.2GB DVD. The time was approximately 1 hr 15 minutes on a AMD XP 2200.Originally Posted by Gurm
Now Chrissy likes to brag about his P4 doing it in half that time but I don't believe it
Ok so about double then. My 1800+ takes about 40 minutes to do 2 SVCD's... 1'5" to do 3.
- Gurm -
Gurm: the whole process duration is doubled if you apply the sde fix?
Oh! I don't know, I haven't tried it yet. I'll be setting one runnning before I leave for the afternoon, so when I get back I'll post and let you know.
LAST time, I encoded:
3 x 700+MB SVCD, 480x480+MP2 sound @ 44khz
to
1 x SVCD-DVD, AC3 sound @ 48khz
Of course the sound didn't work, and neither did the picture. D'oh! But it took 59 minutes to complete.
I'll post how long it took to encode to:
1 x SVCD-DVD, MP2 sound @ 48khz
And then we can calculate the discrepancy in audio encoding time and figure out the % gain from doing the headers.
- Gurm
Clarification on multiAVCHD converter...
By ranchhand in forum Video ConversionReplies: 2Last Post: 28th Feb 2011, 15:16 -
A Pioneer DVD fix it problem
By kenmt in forum DVD & Blu-ray RecordersReplies: 6Last Post: 23rd Jul 2010, 09:03 -
Pioneer DVR video outputs not working - possible to fix? other options?
By JimmyMcV in forum DVD & Blu-ray RecordersReplies: 2Last Post: 11th May 2010, 00:59 -
Clarification on processor support
By seven_deuce offsuit in forum ComputerReplies: 10Last Post: 14th Jan 2009, 18:57 -
Pioneer Players wont play SVCD2DVD Creations...fix?
By alangriffin in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 2nd Jul 2008, 10:06
