  1. Hi guys !
    I've just bought a Mini DV Camera and after captured some inicial movies in DV format I've tried to convert them with CCE ( that I use since forever with Dvd2dvdr) .
    The DV movies have great quality (of course) and gave no trouble to capture to the hard disc with my capture card fire-wire from Conceptronics.
    The real problem is that when I tried to load the DV files in CCE I've got a "AviFileGetStream: No data" error !
    This is probably some simple thing but that I have no ideia what.
    I've looked in some forums for CCE problems but I found no answer to this.
    I thank you in advanced dear friends
  2. Member DJRumpy's Avatar
    Dallas, Texas
    Your input may be a Type-1 AVI. I don't think v2.5 accepts type-1 input. You can try a convertor in the TOOLS section to convert your input to Type-2.
    Impossible to see the future is. The Dark Side clouds everything...
  3. Thanks !!...
    I'm going to try now to convert to type2 with Ulead Media Studio Pro 7.0.
