  1. I have some old backup I made in DIvX and Xvid long time ago
    since I have a DVD burner and some Princo disk to scrap, I would like to try some conversion.
    I did the tutorial with TMPGEnc, but I can't keep the aspect ratio. It's always 4:3 or with 2 black bar left and right (???)
    How May I convert those movie and keep the ratio !
    thanks
  2. Banned
    Dec 2002
    I think you should just pull out the original discs that you made backups of and use a DVD compression program to make it fit on your DVD.
    the quality from divx to DVD is not good at all
  3. Originally Posted by jarvis1781
    I would, but it's captured video that I archived some time ago.. I didn't had a DVD burner in this time so I made backup of my footage on 2 cd in DIvX... I don't have any source beside of that !
    are you using those settings??
  5. if I choose this option, it turn the movie in 4:3 ! full screen
    the only way I can get the good ratio is select manual resize and put 720 * xxx but i don't have the exact same ratio
