Hi Major,
Thanks for the hard work and regular updates you put into ffmpegX!
I've got a problem with the engines intaller however. After I located all of the files, I get an Applescript Error -102 as soon as I click the Install button.
I've tried moving the installer off of the disk image to the boot partition. I also moved all the required files (mplayer, etc) to the same directory as the engine installer. So far I have not had any luck.
I'd appreciate a little guidance.
AnonymousGuest
I get the same error, I tried installing the Applescript update (1.8.3) only to find out that I had a newer version (1.9) in Jaguar already.
AppleScript Error when trying to author DVD with subtitles
By Chopper Face in forum ffmpegX general discussionReplies: 5Last Post: 2nd Jul 2008, 23:25 -
AppleScript Error _iframeflag is not defined (-2753)
By linea in forum ffmpegX general discussionReplies: 3Last Post: 30th Jun 2008, 12:51 -
By linea in forum ffmpegX general discussionReplies: 10Last Post: 30th Jun 2008, 12:46 -
AppleScript Error
By stembridge in forum ffmpegX general discussionReplies: 5Last Post: 1st Mar 2008, 09:44 -
Applescript error in Leopard build 9A527
By rbrakes in forum ffmpegX general discussionReplies: 14Last Post: 17th Dec 2007, 12:18
