Results 1 to 10 of 10
  1. Ladies and Gentlemen I need some help. I recently purchased an external case to put a 7200 60GB hard drive in to use with my Laptop running Win ME. The problem is I cannot get the drive to recognize under Win ME. I work mostly with XP on my desktop, so Win ME has me puzzled. How do you get the external drive to recognize with ME? It is connected via a 1394 Firewire cable. The drive was formatted when I put it in the case. I can't remember if it was NTFS or FAT32. In any case how do I get it to recognize? If anyone can help I would appreciate it! Thanks so very kindly!
    One more thing
    It recognizes under the disconnect icon on the system tray, but does not recognize in My Computer. This has me perplexed!! (big word I've always wanted to use!!)
    Aug 2002
    Behind the wheel of a R34
    WinME cant read NTFS.
    XP can read FAT32 and NTFS.
    Maybe thats ur problem.
  3. Yes I know ME cannot read NTFS. That's why I am asking what utility is it that will allow me to format this drive?
    Aug 2002
    You want to format an HDD?
    Boot up in MSDOS...
    Type (Drive Letter of HDD) for example
    D:\ Format D:\
    or something like that
    or D:\ Convert FAT32 or NTFS
    I think thats the lines go..
  5. Member The village idiot's Avatar
    Apr 2002
    Adrift among the STUPID
    control panel --> add/remove hardware ---> add a new hard drive (maybe?) That should create a partition that it can see, then just format the thing..... Maybe?.....
    Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they?
  6. Well let me call myself stupid before anyone else does!! It helps to set the jumper right (just pull it off!) before putting the drive in the case! Boy do I feel stupid now. Thanks for the help anyway. The drive works fine!! Now I have 60 extra GB for video editing.
  7. Banned
    Nov 2002
    Pgh Area
    Preacher,
    Kudos to you!
    You didn't just slink away, after you found a "dumb" error.
    Good on you, guy.
  8. Thanks!
    But I still feel pretty stupid! I do this everytime I add a drive External or Internal! You would think I would learn by now!! BUT NOOOOOO!
    Aug 2002
  10. Member The village idiot's Avatar
    Apr 2002
    I did that too! Don't feel bad.
