Is it possible to take an avi file and REPLACE some selected part of video without altering the original soundtrack ? If yes, pl suggest the method. Thanks
AnonymousGuest
With Premiere you can. Use the razor to cut the section. Then in a menu somewhere you can unlink the audio/video for the selected clip. Then select just the video and delete it. Then add your clip in it's spot. The section you are replacing needs to be the same size.
Hope this helps.
Jamie
Video Editing Software: mkv, h264 & DTS Editing?
By techdls in forum EditingReplies: 8Last Post: 28th May 2011, 02:29 -
What is the best editing software for editing head
By sonic12345 in forum EditingReplies: 1Last Post: 4th Jul 2010, 22:05 -
Editing as a career / editing freelance jobs
By ayim in forum Newbie / General discussionsReplies: 8Last Post: 15th May 2010, 22:31 -
HD Editing
By A Jungemann in forum ComputerReplies: 3Last Post: 21st Sep 2009, 17:53 -
Basic editing: which Mac program for my DVD editing situation?
By Nuevonik in forum MacReplies: 4Last Post: 8th Jan 2009, 08:06
