I've been trying to Convert a Very long WAV file to AC3 with version 006 and now with ver 007. I always get this error sequence in the terminal:
MEncoder dev-CVS-030226-15:00-3.1 (C) 2000-2003 Arpad Gereoffy (see DOCS)
AltiVec found
Reading /Users/man/.mplayer/codecs.conf: can't open '/Users/man/.mplayer/codecs.conf': No such file or directory
Reading /usr/local/etc/mplayer/codecs.conf: can't open '/usr/local/etc/mplayer/codecs.conf': No such file or directory
Using built-in default codecs.conf
File not found: 'frameno.avi'
Reading config file /Users/man/.mplayer/mencoder: No such file or directory
success: format: 0 data: 0x0 - 0x3E17502C
Audio file detected.
sh: line 1: 607 Bus error
Then everything stops and that's it.
The file come's from a Quicktime converted AIFF file. I'm trying to increase the gain as DVD studio PRO APack lowers tremendously the sound track level to my movie.
Its almos 1GB long as it's the mixed track from a 94 minutes DV feature. I did the Editing on Sys 9 with now defunct EDITDV/Cinestream (the best editing program for the Mac ever done). While the video uses RADIUS DV codecs not available on OSX, howevere the Audio Codecs is quicktime AIFF so this shouldn't matter.
I am lost here. I used succesfully ffmpegX to convert DVDs to SVCD and it never gave me any problems. However I cant put my own movie to DVD because of this very low volume sound problem.
Any hints?
I'm using a Powerbook G4/800 and an IMACG4/800 OSX 10.2.6 with quicktime 6.2 and no frills (standard DEV stuff installed)
Thank you
Dat Ting![]()
Well now I get this:
Last login: Tue Jun 3 03:26:10 on ttyp1
pbpaste | sh
Welcome to Darwin!
[adsl-sta-tpe-62-3-189:~] man% pbpaste | sh
Encoding started on Tue Jun 3 03:29:15 CST 2003
Input #0, wav, from '/Users/man/Movies/DVDtest/UNALTRAVITA.wav':
Stream #0.0: Audio: pcm_s16le, 48000 Hz, stereo, 1536 kb/s
No audio or video streams available
INFO: [yuvscaler] yuvscaler (version 1.7.0) is a general scaling utility for yuv frames
INFO: [yuvscaler] (C) 2001-2002 Xavier Biquard <xbiquard@free.fr>
INFO: [yuvscaler] yuvscaler -h for help, or man yuvscaler
**ERROR: [yuvscaler] Could'nt read YUV4MPEG header!
**ERROR: [mpeg2enc] Could not read YUV4MPEG2 header: system error (failed read/write)!
questions about audio normalizing and audio encoding
By codemaster in forum DVD RippingReplies: 2Last Post: 25th Sep 2011, 21:22 -
AVStoDVD crashed on audio encoding.. have m2v video file, but no audio
By arcooke in forum Newbie / General discussionsReplies: 3Last Post: 5th Aug 2010, 14:18 -
Help with audio encoding
By tooonami in forum LinuxReplies: 1Last Post: 11th Jul 2009, 18:55 -
encoding with DTS audio stream - Audio not found in AutoGK
By extrabyte in forum DVD RippingReplies: 1Last Post: 7th Jan 2009, 16:42 -
ffmpeg -- encoding while muxing new audio w/out source's audio, how ?
By vhelp in forum AudioReplies: 8Last Post: 21st Nov 2007, 19:53
