How do you burn an ISO file to CD using NERO?
I've tried and and saved them a CD ISO. What next? All that happens
when I look at the cd's are it shows a WINRAR file which then won't unzip.
Anyone know what's going on?
Normally, when it say File system RAW is because, haven’t been burn. So first check your NERO settings, goto Recorder----> Choose Recorder, and check that you have you CD-RW unit. Second check at the Burn screen, that Simulate is uncheck and write is check.
Another thing that you can try is Daemontool (Download it from the tools at your left) to mount that ISO image in a virtual CD an take a look, what is in that image.
Some Day I will…..
You can also go to www.winiso.com and download WinISO and check to see if its a valid ISO.
If you made this ISO with VCDEasy, that may be your problem. Are you sure its an ISO and not a BIN with an ISO extension?
Blu-Ray ISO question
By chou560 in forum Authoring (Blu-ray)Replies: 2Last Post: 16th Mar 2010, 09:44 -
Question about using winrar to detect corrupt iso file
By jimdagys in forum ComputerReplies: 1Last Post: 13th Oct 2008, 19:07 -
DVD9 Iso to DVD5 question
By winman42 in forum DVD RippingReplies: 4Last Post: 13th Sep 2008, 14:12 -
ISO and MD5 Question
By baconharvester in forum Authoring (DVD)Replies: 6Last Post: 20th Sep 2007, 22:50 -
Iso to Xvid Question
By boing in forum Newbie / General discussionsReplies: 2Last Post: 8th Jun 2007, 23:05
