I am tying to decode a movie from Xvid to vcd…. At the end of the decoding session I get an msg saying “invalid pointer operation” ! Anyone here that can help me fix that problem…..?
Look like you are trying to "encode" a Divx movie into MPG for VCD.
You need to give the details of your encoding parameters before others could help.ktnwin - PATIENCE -
Try looking here, if you can't cure the problem post back
G luck
https://www.videohelp.com/forum/userguides/119019.php -
I have tried the guide now… tried to burn it on an cd… black screen, and the sound from the film…
I think I have to find out how to delete all codecs from my computer, and finding some that works……
“You need to give the details of your encoding parameters before others could help.”
That is a problem… and that is why I use the newbie forum for this question… I have no idea what “encoding parameters” and why I should know it is out in the blue to! If I knew things like that… I would use one of the other forums…
Codecs are the likely cause, If you have Nimo installed you can remove them from add/remove in control panel. Any other codecs you can check your start menu or/and programme files and see if their is an un-installer for the codecs you find.
I would also recommend you do a registry clean after you have removed them with this....
http://www.vtoy.fi/jv16/shtml/regcleaner.shtml
Anything the codec has put in there just select it and click remove.
Then you can start again with a fresh set of codecs, check the tools section to the left for these.
Good luck and relax, the fact that ppl are answering you means they are trying to help you out.
(Encoding parameters = Encoder you are using, settings, media player etc etc) -
Thanx... I will try to remove and find some new codec.... and probably report back and ask more questions....
MPEG-2 TS PAT header decoding problem
By jeromedroz in forum ProgrammingReplies: 21Last Post: 27th Jan 2016, 04:02 -
Virtualdub and AVC file (decoding problem)
By EdoScario90 in forum Video ConversionReplies: 4Last Post: 12th Dec 2010, 11:33 -
DVD to DivX - Chapter Decoding Problem
By Nuin in forum DVD RippingReplies: 0Last Post: 25th Mar 2009, 17:56 -
DVD decoding problems with TMPGEnc 3.0 XPress
By shorto in forum Newbie / General discussionsReplies: 2Last Post: 21st Aug 2007, 12:16
