i am looking for the best updated tutorial out there to convert all my avi movies to vcd. and how long does this process take?
thanks!
tvandang
tvandang
https://www.videohelp.com/tmpgenc.htm
depends on you processor size.
I have 2.1ghz p4 and it takes about 3 hours for 90min movie"Today is only yesterdays tomorrow" -
vcd's suck...try svcd's if your player supports them:https://www.videohelp.com/forum/userguides/119210.php
yep im starting to agree, svcd are far better than vcds,
i have written a guide that alot of peeps said it really helped them, there are some on the left but if ya want i can send ya it -
I've only tried a couple of svcd's and they did'nt turn out so good.Originally Posted by matneaves
Do you have a good TMPGEnc template?
Is it still possible to make a decent SVCD 90 min movie using 2 cd's?"Today is only yesterdays tomorrow" -
defo
the thing that people go for is the "lets select a svcd template and thats it",
but its not , i never select the templates,
all it requires is a little working out
1st what do you want to do, do you want it on 1 or 2 cd's
then think about the length of the movie
ok for svcd a 700 meg cd=55 mins svcd timewise movie file
so for a film thats about 1 hour 30 mins=90 mins=45 mins per cd
or lower the bitrate to make it fit onto 1, what you gotta realise is what you do when lowering the bitrate is fooling the dvd player into its a normal svcd/vcd but it isnt, technicaly that what your doing
if you want good quality then i would go for 2 cd's
i have a guide i wrote in word, that i can send ya , it explains, in detail what to do, and if ya want it email me at mat_stuff@hotmail.com
i have a few peeps with rouglhy the same(ish) probs as here and they said it helps and i can also help you step by step which guides dont do -
ok.. i will say it again.... try this:
i can't get much more specific than that
although that guide starts well, it does get a bit thin at the ened, ege "slide the cq slider to 80, or if its about 2 hours might need to make it 70 to makes sure it fits"
in doing that you could be losing out in bitrate that could make a dif to the quality
surely its best using a bitrate calc to get the exact bitrate and so squeezing the highest rat to fit
VideoInspector updated to v2.3.0.126
By Kyle_Katarn in forum Latest Video NewsReplies: 0Last Post: 6th Nov 2011, 16:33 -
Tools not being updated as often these days
By G)-(OST in forum Off topicReplies: 5Last Post: 22nd Jul 2010, 22:44 -
Updated Drivers Software
By mn072065 in forum ComputerReplies: 7Last Post: 9th Mar 2009, 06:23 -
Updated TMPGEnc
By avz10 in forum ComputerReplies: 4Last Post: 24th Jun 2007, 14:20 -
VideoInspector updated to v1.10.2.109
By Kyle_Katarn in forum Latest Video NewsReplies: 0Last Post: 20th May 2007, 15:03
