  1. judethecat
    Guest
    hi
    newbie here
    can anyone help with strange problem
    i set everything up exactly to guide and press start
    it all seems to work
    and createstwo folders which i hoped would contain the finished files
    but when i open them there is no files inside
    thanks for any help you can give
  2. If you're using (s)vcd2dvd+ then it might be that you got a wrong version of besweet only 5.17b works
    Yf
  3. judethecat
    Guest
    hi thanks for tip got latest version now
    seems to write folders now
    in video folders there are a few files
    in the audio one none is this right?
    also when i try to write to dvd error message using
    copy to dvd
    sorry to ask
    steve
