I just ordered my FIRST (!) camcorder!
I want to transfer my home movies to DVD, and as far as I can tell, I guess I need a firewire card. Which model will give me the best quality? Do I need a whole new video card, or is that unrelated?
Thanks for any info!
-Brian
it doesn't matter what firewire card u buy...i bought a noname one and had no problems what so ever...about your video-card...do u mean graphics card or some form of video editing card....what u definitly need is a fast processor, lots of RAM and a big HDD.....the movie files wont be small when u capture them uncompressed...you will also need software to capture it and software to burn it to DVD with maybe some funky menus....this will cost you money....
"Some people see things that are and ask, Why? Some people dream of things that never were and ask, Why not?" -
I purchased a DV starter pack which featured a firewire card with three ports, and Ulead videostudio5. It has worked pretty well in the 6 months I have had it. If you don't need the software then most cards seem ok- you can get combination cards with firewire and usb2 ports, which might be handy for printers etc. I am going to have to add a new HD to the computer soon so i am thinking of getting a external drive connected through firewire. Whichever way you go, you won't be disappointed.
newegg.com search for firewire get the $18 one. I've ordered 4 of them and had no problems I think it's GWC or something like that. Just use Texas Instruments OHCI 1394 driver for windows 2000 for your driver selection if your using wins 2000 that is. It has 3 ports.
Thanks for all the info, guys.
I have a plenty fast machine, the necessary software, and probably will need another hard drive, but I was most concerned about the firewire card, since that's new to me.
Appreciate the info.
-Brian
What do you used for a PCI xpress firewire card?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 7Last Post: 5th Sep 2011, 21:45 -
Need to buy a suitable PCI X firewire card for my newish PC ASAP
By Canon GL-2 Guy in forum ComputerReplies: 2Last Post: 5th Sep 2011, 00:08 -
URGENT! Firewire card for computer
By dakota413 in forum Capturing and VCRReplies: 9Last Post: 10th Aug 2011, 18:22 -
Motherboard Firewire versus Add-in Card Firewire
By SCDVD in forum Newbie / General discussionsReplies: 7Last Post: 19th Jun 2008, 12:19 -
What Firewire Card for a Camcorder?
By rakun in forum ComputerReplies: 5Last Post: 12th May 2007, 10:20
