Hi !!!
I´m new in this forum !!
i bouhgt SVCD2DVDMPG+ an it works very fine for me !!!
But one question :
I merged 3 SVCD mpgs to one big mpg 2,2 Gig !!!
Afterstarting SVCD2DVDMPG+ only the program starts in the dos-box and disappears!!
So i split the big file into two files and it works !!!
So now my question :
What´s the limitation for the SVCD mpg file !!
big thx for your replay !!!
I don't know the file size limits so I leave that to Chrissyboy.
But you don't have to merge, you can add all video files and they will play after each other. -
Guest
but the second svcd mpg starts normaly 2-5 seconds before the end of the first svcd mpg!!!!
Thats just due to the fact that the SVCDs were created that way - for continuity whilst you change the disks over.but the second svcd mpg starts normaly 2-5 seconds before the end of the first svcd mpg!!!!
Clearly there is a limit to size. As the standard process is to take either disk images or svcd mpegs aprox 800MB i haven't tested with huge files. The philosophy behind the tool is not to join mpegs - let your authoring software do that.
At what stage does it fall over?SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Guest 2Guest
I have the same problems like you. I merged 2 files with tmpeg and svcd2dvd+ doesnt start converting. It created only the 2 dvd folders audio and video. I guess it has something with the lenght of the movie to do because I did ist also with a 90 min movie (file size > 2gb) and it worked
so long -
toxmanGuest
I have to confirm I encountered the same size limit problem, after I used DVD2SVCD to rip and convert a DVD movie into 1 big SVCD mpeg. It wouldn't load into SVCD2DVDMPEG+ and when I used the "MPEG Info.." right click menu on it, it would say it's not a compliant file. I didn't realize SVCD format has a limit like that, so it puzzled me for a while as to what I did wrong when encoding DVD to SVCD.
-ToXMaN
x264 codec decoding limitations
By Medieval1233 in forum Portable VideoReplies: 2Last Post: 30th Dec 2011, 18:54 -
? about scan limitations for AV programs
By Seeker47 in forum ComputerReplies: 1Last Post: 10th Feb 2011, 15:15 -
MPEG-limitations in AVIdemux?
By Gew in forum EditingReplies: 9Last Post: 9th Apr 2009, 09:55 -
Limitations of Ulead DVD Workshop2
By raouliii in forum Authoring (DVD)Replies: 10Last Post: 20th Oct 2007, 02:42 -
Area Limitations
By jmsrickland in forum Newbie / General discussionsReplies: 2Last Post: 23rd Sep 2007, 22:10
