I have released a build of SVCD2DVDMPG+ which has a preview of the new proposed menu system https://www.videohelp.com/forum/viewtopic.php?t=159970
Its basically 3 templates (NTSC 4:3) for use with 2 VTS DVDs. The templates are simple (I'm no designer), but you will get the idea.
Just do an update from your menu to get the build.
Comments welcome.
Results 1 to 10 of 10
Tried it and it crashed when I clicked on the Menu button. I had added 3 bins and dragged one 1 to a new a VTS.
Yep - i forgot to mention you need the "menu pack".
Here it is:
Extract this zip to your install (svcd2dvdmpg+) directory (using folders within the zip)
zip password is: menusRGr8
http://www2.svcd2dvdmpg.com/menu_preview.zipSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Not yet - been sorting out some other things....
The current pack is more of a proof of concept. That said it is usable within the stated constraints. If your dvd player plays NTSC & PAL then you can have the NTSC menus with PAL movie content.... just a thought.
The main theory behind the new menu system is (when i have settled on a spec) that other people create menus to share in a public gallery. I dont want to spend all my time attempting to be creative when there are people out there who naturally are!SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
AnonymousGuest
trying to use the menus but the button is greyed out, does it apply the menus auto at the moment ??
Originally Posted by Guest
Did you get the "MENU add ons" from here?
https://www.videohelp.com/forum/viewtopic.php?p=542033#542033 -
AnonymousGuest
Menus are not working for me
I change the names for the 2 films i have put on then i chose to continue and the program closes each time?, it comes up with an error that a file is missing?
any ideas?
cheers -
May I suggest you try the latest version.?
1) do an update
2) delete your Menus Folder
3) download the latest menu pack (http://www2.svcd2dvdmpg.com/release/menus.zip)
4) Extract this zip to your install (svcd2dvdmpg+) directory (using folders within the zip)
Its a bit more mature in its error handleing too.
Guide for extracting menus for editing, and reinserting edited menus
By manono in forum Authoring (DVD)Replies: 167Last Post: 8th Dec 2022, 02:44 -
Better Menus
By clinging2thecross in forum Authoring (DVD)Replies: 3Last Post: 13th May 2011, 05:10 -
Menus folders or sub-menus
By GymDad in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 9th Nov 2008, 07:43 -
Help with menus
By miickEe in forum Authoring (DVD)Replies: 11Last Post: 5th Mar 2008, 20:45 -
Magix Movie Edit Pro Menus and Sub-menus
By gayclarke in forum Authoring (DVD)Replies: 8Last Post: 11th Aug 2007, 10:07
