The split tool no longer functions in 0.0.7.. may be because of os x 10.2.6..but i get an applescript error when i hit preview: No result was returned from some part of this expression. (-2763)
when I try to hit spit--it takes like 2 sec and it says Finished..yet there is no file anywhere
dmaestro3Guest
dmaestro3Guest
when I try it with version 0.0.6m it doesn't work anymore either (not sure if it's due to new installed files--but i don't think they changed) ... here is the error I get under .6m it worked before:
dyld: /usr/bin/mencoder can't open library: /usr/local/lib/libvorbis.0.dylib (No such file or directory, errno = 2)
dyld: /usr/bin/mencoder can't open library: /usr/local/lib/libvorbis.0.dylib (No such file or directory, errno = 2) (133)
well it appears as though it moved the mencoder and it needs it...but under 0.0.7 I listed the error I got.
Have you installed the libvorbis and libogg packages coming with the application, as indicated in the online manual?
Broken or not broken hard drive?
By romanstopme in forum ComputerReplies: 3Last Post: 17th Sep 2009, 13:04 -
VobBlanker DVD Split- Automatically jump to Split Title
By src2206 in forum DVD RippingReplies: 12Last Post: 11th Dec 2008, 08:58 -
Captured AVI frames broken/split/badly aligned
By cyclometric in forum Video ConversionReplies: 3Last Post: 25th Sep 2008, 08:50 -
Split Mpeg or convert to AVI then split. What to do?
By oldfart13 in forum Video ConversionReplies: 4Last Post: 24th Mar 2008, 01:00 -
Procoder split/split by size/media query
By kippard in forum Authoring (DVD)Replies: 7Last Post: 17th Nov 2007, 23:35
