Results 1 to 10 of 10
  1. i'm trying to burn an mpg file and i keep getting the box show up (foreign image settings)-how do i go about fixing this.
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    What are you trying to create? A data disc? A VCD/SVCD/DVD? Are you using a Nero Wizard?
    /Mats
  3. i have an mpg file-i'm just creating a new compliation and when i go to burn it comes up with the box(foreign image setting)-trying to burn svcd.
  4. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Well, my standard reply for Nero issues:
    Scrap it. Use VCDEasy for authoring and even burning. If your CD writer isn't supported by VCDEasy, just create the cue/bin with VCDEasy, and burn that with Nero. It's good at writing stuff to a CD/DVD. It's not good for anything else. (Even if I must admit I like it's CD cover editor...)
    /Mats
  5. thanks Matts
    one question thou-how do you go about creating a bin/cue file from an mpg file with vcdeasy.i want to burn it on cdr.
  6. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    That's the purpose of VCDEasy - to create a cue/bin pair containing a (S)VCD image from one or more mpegs,(and possibly burn it to CD). To stop after creating the cue/bin, (and not burn it) just uncheck the burn checkbox.
    /Mats
  7. hey Mats
    is this the simulate process that VCDeasy uses when running thru and verifing the file and makes a xln file when done.
  8. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    No, the simulate performes the burning action, with the laser turned off. If both Simulate and Burn are checked, it will create the image, then simulate a burn, then do the actual burn (when you hit Go).
    With neither Simulate nor Burn checked, the image (cue/bin) will be created, but nothing more will happen. You can then locate and use this cue/bin using the File -> Burn Image option in Nero.
    /Mats
  9. hey Mats
    realy appreciate all your help with this,was able to create bin/cue no problems,but now i have to figue out how to fix my other mpeg file within winrar.i'm not sure if you could help me on this one-when u double click on the rar file and it generates the mpeg-then i try to extract it to another location it tells me its corrupt.
    thanks again Mats
